Hi everyone, I'm new to this site and am hoping someone can help me with a slight problem on my UK spec 1999 SLK 220 Kompressor (62,000 miles/100,000 Km).
When I put my foot down hard with the gearbox in automatic mode, the car accelerates but then keeps holding back (almost like stuttering) and just doesn't want to accelerate smoothly. If I then push the stick accross to the manual setting it accelerates perfectly with no hesitation or holding back??
The gearbox works perfectly at all general around town speeds, it's just when I try to accelerate hard.
I tried to check the gerabox oil in case this was low and an easy fix but found that the car doesn't have a dipstick as expected? Can I make my own dipstick or does anyone have any other suggestions as to a possible cause.
Many thanks in advance
2004 CLK 240 Coupe
If your ATF is the original from the factory, it's probably time it was changed anyway.
I have read here about a guy who used a piece of flexible curtain wire as a cheap DIY dipstick. - cost about 20p/metre. There will be a M-B dipstick available from the spares counter, but it will be expensive for such occasional use... Depending on what gearbox you have, you can either change all of it (including TC) or just some of it. Lots of discussions on the forums about this topic.
Use the UserCP ^^ to add some details, eg location.
