Help... how do I remove the plastic cover for the overhead light above the rear view mirror? I like to tap off 12V for a radar detector.<br>
<br>
Discussion Starter #2
you press upward on the light lens itself and it pops out at an angle...then remove. two screws upward in the light sockets connect the whole housing to the frame.<br> you will have to remove the rear view mirror to remove the housing. the mirror is just in a 'socket' with a spring tension. no bolts, just needs to be 'carefully popped' out... be careful not to break anything... good luck<br> <br>
