1997 MBZ SL320
Can someone tell me where the cut-off relay battery/battery auxiliary is located? My car has gone totally dead, and the windows are stuck in the down position. I believe that the relay is the problem. Suggestions or advice is welcome.
· Greek God of the R129
SL500-500SEL-190E
Hmmmmm.
That a new one.....
I don't think we have one, that will disconnect the battery.
Unless is an after market, that will disconnect the accessories.
I suspect that your battery is dead, slight possibility, fuse blown.
Look for them, in the fuse box located in the trunk.
Do the headlights turn ON?
If they don't most likely you need a new battery.
If you decide to do charge.
First disconnect the battery.
Or, it may cost you big time.
Do a forum search, plenty info.
Welcome to the forum.
Regards,
aam.
