1 - 9 of 9 Posts
w126 300SD 1981 - Vito W638 108 CDI 2000 - W209 CLK cabrio 2003
Can someone help me out with a problem I have with my SL300 R129.
When the engine is warm and in idle position the oil level is below 1.
There is no oil loss. When I put the gaspedal down the oil level is 3.
Is it normal that the oil level is below 1 when idle and engine warm?
thanks.
Greek God of the R129
SL500-500SEL-190E
CK the oil thickness and temperature you are.
Most likely your oil is to thin.
Regards.
aam.
E350 Sport
i use 20/50 and will see a little over 2 idling.
thanks for the replies.
i will put 20w50 in tomorrow.
I would assume you are talking about the oil pressure gauge, not the oil level. The conditions you describe are perfectly normal. See your owner's manual.
I can't believe they would even sell 20/50 in The Netherlands, but whether they do or not it would be a really bad idea in that climate.
Discussion Starter · #8 ·
They do sell 20w50 in The Netherlands. I have bought it a couple of days ago. Have not yet put it in though.
After reading the replies up till now, I have checked the manual, but it is a bit of a mystery to me. I called a MB-dealer here and they advised to put in 10W40 for this 300SL 1989. (when the engine looses oil more they advise 10w60).
So I think it is best to take the 20w50 back to the shop buy the 10w40 instead.
Oil viscosity is not addressed in the owner's manual, but in an ancillary "approved fluids" brochure that came with your car. It has a high/low temperature range chart, which indeed is likely to say that 10/40 would be fine in your climate. But to your original question your oil pressure is fine now.
1 - 9 of 9 Posts
