When I heard that it would be $800 to install SIRIUS (and I had two PNP units already) I took it as a personal challenge to get it done myself. With some help removing interior panels, I was able to install the SV1 (radar-detector sized) unit in my ashtray with an in-line antenna adapter for a clean sound. It works perfectly, and power comes from the cigarette lighter. You have to be careful to tap the right wire at the c-lighter (auto headlamps will turn it off in the daytime). Can't remember color, but if you attempt, when using an electronic tester - test twice = once with lights on and once with them off. If there is no change, you've got the right wire.
Hope pics come through OK:
