1985 500sel and 500sec 2012 E63 1989 Porsche 911
just wondering if this is a straightforward job, do u need to remove the main headlights to get to the corners, or do they just unplug and pop out and put the new ones in? thanks
1991 300 SE
It’s straightforward – the corners attach directly to the headlight assembly. You need to make sure the two attachment points are lined up and the corners are snug against the headlights and the sheet metal. There are two large plastic fasteners that attach the corner light to the assembly.
so they can be changed without removal of head light?
2008 S550 designo
vdubpower - 5/6/2005 7:30 PM
Yes. Look inside the engine compartment and you will see a large thumbwheel type connector. Remove and slide unit towards the front of the car.
tw
