1 - 9 of 9 Posts
Mercedes
Hey all. I’d appreciate it if you could take a sec and listen under the hood of my 2005 SL55 AMG with 63,000 miles. Note: this is after the engine is warm and is not at cold startup.
To me, it sounds like a bearing of some sort down low on the passenger’s side of the engine. In the 4 years/15,000 miles I have owned the car, that sound has always been there. I am the second owner, and the previous owner always had it serviced at the Mercedes dealer for every little thing. When I visit an independent shop or local Mercedes service center, not one service writer or mechanic has ever mentioned it ... so I assume it’s normal?
Since I've owned the car, I/or a shop have replaced the following parts that might relate in some manner:
  • All belts, tensioners and idler pulleys
  • Alternator
  • ABC pump and reservoir
  • Supercharger pulley bearing (Nachi Heavy Duty Bearing 45BG07S5A1G-2DL)
Even though I have heard this sound on other YouTube videos, it doesn’t sound right to me. It’s as though something is failing so any input would be much appreciated!
Thanks,
Bob
2003 sl55amg
Mine has 82K miles and doesn't make that sound. Try using a long screwdriver in various spots with the end touching your ear to locate it. The A/C clutch may be noisy comes to mind.
Mercedes
cbr1000dude: Thanks for the reply. I tried the long screwdriver on the supercharger -- not a match -- but I was reluctant to get that driver down deep on that running engine. Not much room for error with all those moving belts and pulleys. If I can find a long wood dowel I will give it a try soon.
2003 sl55amg
I made a short movie of mine running with the ac off, but it won't post for some reason. You might try pushing the ac off button and see if it changes.
Mercedes
cbr1000dude: Thanks. I will try that AC off tip, but I believe it was there regardless. I will confirm though.
About that video, perhaps you have it set to private viewing only?
Mercedes
I tried the AC off, but no change. After probing around with a stethoscope I'm pretty sure that it's the air conditioning unit making the noise so, even though it's been like this for as long as I've owned it, I may as well find a shop to do the work and put in a remanufactured unit. I don't feel like taking that front end of the car off myself.
2003 SL55; 2011 E350 BTC
I'd take the belt off and spin all the pulleys and bits to check for loose or rough bearings. It's a quick lever on the tensioner with a breaker bar and I believe 15mm deep socket to pull the belt. You may find a few items that need attention, and you can replace the belt and keep your original for backup. Every used MB I have purchased needed a pulley or 2.
1 - 9 of 9 Posts
