Can anyone recommend a shop in bay area to weld in a catalytic converter, in SF bay area? Anyone have recent pricing on shop charge to do this?
I have 1999 E320 with around 72k miles. I just heard a rattling noise around the catalytic converters' location. I will do some more checking and may bring it in to indy shop for an opinion, but a bad/ failing cat seems to be consistent with the fuel trim data that I have been seeing on this car for the last couple of years. I think I had even started a thread a while back about poor gas mileage, and couldn't understand the elevated fuel trim as a function of intake air temp. Now, it seems to make some sense if the cat was getting more clogged during a drive cycle, particularly during city driving. Freeway driving during the drive cycle would slowly bring down the positive fuel trim--an indication that the higher engine RPM was able to force the exhaust through the clogging cat?
Anyway, I may add some more diagnostic info to this thread as I try to pinpoint/confirm bad cat. I have never had a check engine light come on, in this car. I did have a pending error code on bank 2 pre-cat O2 sensors recently and have changed that sensor. I am not sure if that issue was related to a failing cat. The pending errors were for an O2 sensor heater circuit problem and narrow voltage range on output signal.
Based on G-AMG's sticky thread, I am planning to get MagnaFlow catlytic converter(s) as replacement. These parts are now available on amazon @ around $145 to $160 each, from different sellers. For my California vehilcle, it appears that MagnaFlow 441304 and MagnaFlow 444104 are the correct cats for rears and fronts, respectively.
