shifts smooth but shifts into 4th gear to early. When first start up cold does better but after warm up at about 30mph and doesn't have enough power to get up to speed. Has anyone else had this problem and what was the solution? Thanks for any help. oldcarpappy.
96 E300D
Don't have a 240D but I think the answer is the same. Adjust the bowdin cable on top of the valve cover. Turn the nut so the cable gets tighter, no more that 1/4 turn at a time. Test and adjust again if needed.
