1 - 11 of 11 Posts
My gear shift wont go past drive like to the lower gears. What should I do?
I have a 99 E320 rear drive.
Welcome, please click user cp and edit details to add your vehicle and location to your profile, it's useful information when you're seeking assistance.
By stuck, do you mean the lever won't move, or that you can move the lever but can't manually engage the lower gears?
Okay, then I'm officially confused.
"D" is as far as it can go, then it's left or right to select gears...at least on all the shifters I've seen.
How is yours set up? A pic might help, too.
Ah, pre-facelift, that's true. Good call.
Likely it's in the shifter mechanism, pop up the console and check it out.
Yea it stops at drive and won go to he left it is just suck there. i took the plate off and it looks fine but i am new to the car so any suggestions?
Any work done recently on engine or transmission mounts?
Put shifter in D. Get under car. Loosen screw 99 (T27 Torx) shake shifter rod (63) to relieve tension and tighten screw. Check condition of shifter linkage bushings.
1 - 11 of 11 Posts
