I have a 2002 ML320 that won't shift out of park (without a bic pen)... It was a situation that occurred once, then went away, came back and now is here to stay. That leads me to believe there is a loose connection somewhere.
The brake lights function without issue. There are no dash lights on to indicate brake switch failure. Also, the dash shift lever indicator functions correctly as well. No issues with the manual shifting either.
I've pulled the console apart, removed the shift unit. I've inspected the solenoid and it does function when powered externally. I've taken the shift unit fully apart, inspecting a little further, everything looks solid. I was not able to get as deep into the shift lever location electronics as I wanted... I'm thinking the problem may still be in there.
The wife says there was no water spilled on the console and I see no indication of that.
So, i'm kinda stuck. I'm thinking that i'll remove the safety until I can find a replacement unit as, I've hit the wall with what I can do without buying new parts. Do you think the issue is withing the shift unit electronics?
Is there anything else you guys can think of to check? Thanks for reading!
