W126 300SDL, W140 S320, W211 E320 CDI
I have a 93 300SD. I want to get under one of the window switches. Can I just carefully pry up on the plastic shifter plate to get under it?
thanks
92 500SEL to 01 E320T current 2014 lexus LS460
NO you cant! To get the panel off open the ash tray, take out the insert, loosen the screw on the ashtray cover (wood) slide up and remove. Then look down into the opening, and locate the two lateral torx screws (not the two pillips staight down) which hol the upper and lower panels together, remove the trim ring and pivot the panel upwards, be carefull of the catch at the rear. The switches are mounted to the panel, change the shifter bulb while in there.
Thanks Peter
Ill give it a try as soon as I get it back
