hi everyone I just got a 1961 404.113-017276 it’s a hicab hardtop with a Peter Bauer box on the back built, I believe, for Deutsche bundespost. I’m having trouble figuring out the shifters. Is it possible that it’s an automatic? The main shifter lever only has three positions, forward, middle and rear, it’s mounted to the large oil fill reservoir in such a way that there’s no side to side movement so it doesn’t appear to be able to make the normal two low/four high shift pattern. There is a clutch and I’m wondering if it’s some sort of strange manual/auto setup. Has anybody seen anything like this? Any wisdom would be greatly appreciated. Pics to follow later today. Also any fleas on the best way to turn the engine by hand? I’ve removed the radiator for access and the fan spins freely in front of the crankshaft and I can’t get any tools on the crank to turn it to make sure the engine isn’t seized.
