2002 CLK55 AMG, 1980 Porsche 928, 1964 MGB, 2015 VW Golf TDi
I'm also having this problem after letting the car sit for a few days. Goes away after 3 minutes of running the car in park (and some pumping of the brakes, although this may be totally irrelevant and purely superstition on my part).
2002 CLK55 with ~270k.
I had a similar problem with my W210. For me ended up being from a weak battery putting out low voltage. I replaced the battery and the symptom has not returned. From my research found it could be a number of things, but I would suggest at least testing your battery. I hope you solution is as simple and inexpensive as mine.
