1 - 20 of 29 Posts
Well the 126 is sold.....for a bmw 318i!
The exspense costs on it were too much to handle.
1988 560SEL
Wow, too bad, the 318 is possibly the worst motor BMW ever built. I have a friend who has one with less than 150kms on it has been thru 2 motors. And then the infamous BMW electricals...
Well good luck, let us know how you make out.
ah damn u gave it away!!
APRIL FOOLS!![:D][:D][:D]
A Bmw over any Mercedes!? Pfft kill me if I do that.
Hey w/gas on its way to $4 or $5 a gallon, hopefully more people on this forum will be dumping their 126's and go back to taking the bus. Fine w/me!
1991 300 SE
BOL – I believed you, what with the way you talk about your 380, I would not be surprised at all. [:(]
93 190E 2.6; 82 300 SD Turbo
MBGary has a lot of weird pictures lol one for every occasion. LOL
Once i liked BMW, but then I didnt. I tihnk the only cars ill ever buy will be 126 chassis'd. even if in they year 2050 i have to have the entire rebuilt chassis and all from a speciality shop i wil ldo it !
Discussion Starter #12
JDC, you're right I do sometimes bad mouth my car but thats only when theres a problem with it then I hate it. We have a love-hate relationship. I sometimes forget how old it is and how it is for its age and thats when I love it again cause its so damn good.
Being 22, at this age were picky and nobody can keep a car longer than a yr for some reason. We just need to try everything but me and the 126 have been through thick and thin so far. I would feel bad to let it go.
450 SL 1976
MRTIKKET - 4/2/2005 2:48 AM
*LOL* I'm currently paying 6$ a gallon... And seriously considering imigrating!!! ...and that's not even mentioning the 180% taxes we have on cars....!! So whatever you guys are paying for a new car, I can multiply with 3 - can you believe that sh*t...
And that's no aprilfools - Benzonline's was a good one!![;)]
380SEC EURO
Benzonline - 4/3/2005 12:37 PM
I knew it! [:D]
I knew it was a joke immediately when you mentioned the BMW...
03' C320 4Matic SS
Benzonline that pic with u cleanin your engine looks like not much is covered in the process is that right? i'm thinkin of just washin my engine and covin the fuse box, and battery or nething i think should be cover i hope it'll be fine i'll be using engine gunk of course
03' C320 4Matic SS
This sounds dumb but can u show me which is the alternator and throttle body?? thanx in advance
03' C320 4Matic SS
i also dont know how to remove the whole air intake?? do i really need to remove the whole intake to clean my engine
Discussion Starter #19
Dont touch the intakes....the alternator is this pulley looking thing below and you'll see a belt hooked up to it and the thing spinning has fins on it.
1991 300 SE
The air cleaner housing comes off by removing the butterfly nut on the center and the clips on the side. The first image is the engine sans air cleaner housing (I misappropriated it from member MBL [}:)]) and modified it some to help you get oriented to the engine lay out. Note that the distributor and P/S pump are toward the front of the car.
As noted above cover the throttle body/air intake/meter plate opening. The second image is the alt, cover that as well it’s located on the passenger side of the car. If you’re using some kind of high pressure thing I would also cover the fuel distributor and EHA unit. Note also the various CIS – E sensor and connector locations, I’d avoid or cover those as well.
Good luck, please be careful – I don’t want you to have to post a thread called “Just cleaned my engine and now it won’t start!�
EDIT: Ok, well it seems I can’t post the alt pic – it looks like a little generator which is what it is.
[:(!][:(][xx(]
1 - 20 of 29 Posts
