2000 ML320 / 1988 300SE / 1985 380SE / 1969 280SE
The right front window makes screeching noise when it goes down.
I am going to take the door panel off and lube the railtrack.
Before the removal of the door panel, would you recommend to disconnect the battery or to remove the fuse for the airbags.
2007 Mercedes ML500 2000 Mercedes E320 1999 Mercedes E430 1996 Mercedes SL320
As long as you don't disturb the airbag or its wiring the battery can stay connected.
