Puzzled!
No headlights
No radio
No brake lights
No OBD power to read codes
No start
2011 Mercedes E350 base model
I was cleaning air filters and went to put everything back together… a ratchet extension fell briefly against the battery terminal and arced.
Now the car is giving the “service required-don’t shift gears” message and won’t start.
After navigating through the menu, it says that the tail lights, brake lights and side marker lights are all burned out. It also says the car is not in park.
This also locked me out of the trunk because the fob or the button wouldn’t work. I was able to get into the trunk with the key and all the fuses checked OK including fuse 73 for OBD.
I pulled the rear light assemblies and you’re not even able to replace bulbs in them. It’s one big unit with everything in it. So I’m assuming if they are all burnt out that I have to buy the entire assembly.
I checked all the fuses in the engine compartment and tested both the auxiliary battery under the dash and the main battery. Both tested good with battery tester.
I read through all the forums, and everyone was pointing towards batteries or the brake light switch because it was locally available. I did replace the brake light switch, but it didn’t do anything.
Some of the forums said that it could be the TCM or ICM module or the things I’ve listed. I can’t imagine that a small arc from the battery terminal to the frame could’ve caused all this damage…
Of course, Mercedes won’t tell me anything and just told me I needed to tow it in. I have a Bosch diagnostic tool and because everything’s dead I can’t even read the codes.
Is there a way to get temporary power to the OBD so I can read the codes? Has anyone ever experienced this? A workaround? Bypass?
Afer a process of elimination, I have determined it must be the fuse, relay power distribution box next to the battery. A2125406250??? The dealership couldn’t tell me what this does but it’s listed as a fuse block, a power distribution center a relay center…. I was also wondering if this was just may be a software problem? Maybe I scrambled the computer when the short circuit happened?
I despise taking it to the dealership where I’ve had bad service from all three of the the ones in my area and I refuse to pay their ridiculous f’n prices!
Any help would be appreciated.
No headlights
No radio
No brake lights
No start
