I was scrolling through my menu system and noticed that I am going to be due for an "E" Service in about 1K miles. Rather than hunt through the books - anyone want to give me some info on what this is and approximate cost?
Here is what you have to do:
Put the key in the ignition and turn to on position - don't start the car
Scroll the menu until you get the Service E indicator
Push and hold the reset button (same one that it used for the trip odometer)
You will see details on the "E" service
Scroll to addition info and hit enter
My car said that it needed services 2,3,4,6,7 (I think)
Go back to your service manual and look at the description of the above services
Aside from a lot of checking, which we know rarely gets done, the three main items were:
- Oil Change
- Poly Belt Change
- Brake Fluid Change
I brought it in for service and the service writer did not recommend changing the belt. At 37K miles, he said this was too premature and that he has rarely ever replaced these belts. (How many times do you have a dealer not recommend a service???)
Hope this helps...
