I have an E320 20004 and I have a service D due in 4 thousand miles. Can anyone please give me a list of things that the shop does for this service so I can do it on my own instead of paying god knows how much money for the dealer to do it.
Thank you all.
2006 E55: 1999 ML430; 2002 E430 4matic; 1988 190E 2.3; 1993 XL883
This is a list I found, hope it helps.
- Change oil and filter
- Inspect brakes for wear
- Lubricate throttle linkage
- Check and correct fluid levels
- Inspect tires and check tire pressure
- Lubricate specific parts according to Mercedes-Benz guidelines
- Inspect for leaks and assess the condition of all components, lines and hoses on the engine, transmission, axles, level control, and steering, fuel and brake systems
- Replace spark plugs (if necessary)
- Inspect and adjust drive belts
- Inspect air filter elements
- Remove wheels and rotate tires as necessary
- Inspect brake system and adjust parking brake
- Check all exterior and interior lamps and windshield washer systems
- Lubricate throttle shafts, door hinges and locks
- Replace windshield wiper insert(s)
- Clean cassette deck head
- Perform a road test
2006 E500W4
D means 4h labor, at $120 per hour = $480 + easily $300 in parts + tax = $900 or so
