1 - 9 of 9 Posts
S-500
My S-500 is sayin i need Service B in 3500 miles. Would someone be kind enough to tell me what Service A and B are and how much they cost without a warranty in Southern California
2001 S430
I ma no expert in this, but I think service A is basically an oil change and dealership would charge something like $200. Service B could be big; in the neghborhood of $1000.
2000 S500 Sport
I had a service B a couple of months ago. The cost was $440. As far as I know it's the same as a service A but also with new wiper blades which cost about $150/pair, hence the steep price. They also top off fluids, replace any blown bulbs, etc.
'00 S500
Service A
Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models
- Ensure the warning and indicator lamps, horn, windshield/headlamp
wiper and washer systems, and seat belts are functioning correctly
- Inspect tires and check tire pressure (including spare)
- Inspect brake pad thickness and disc condition
- Check and correct all fluid levels
- Reset your vehicle's FSS counter
*Model year 1998 through 2004 vehicles are equipped with the Flexible Service System (FSS)
Service B
- Change your vehicle's engine oil and filter
- Replace the dust filter in all SLK, CLK, C-Class and E-Class models,
and in S-Class and SL-Class models without the active charcoal filter
- Replace windshield wiper inserts
- Inspect and rotate tires
- Lubricate and inspect throttle linkage
- Ensure the parking brake, steering play, headlamps and exterior lamps,
warning and indicator lamps, horn, windshield/headlamp wiper and washer
systems, seat belts, and backrest lock (S-Class only) are functioning correctly
- Inspect front axle ball joints and Poly-V-belt
2016 E400 coupe, 2018 GLE350, 2007 CL600, 2019 C43 coupe
I'd really try an independent MB garage. I got the Service B schedule done for $400 and it included a trans fluid change and filter. the dude told me that sometimes the filter o-ring fails and the filter drops into the pan. It's cheap insurance.
Check your owner's manual and please stop SHOUTING, we can hear you.
2002 S500, 1993 Nissan 300zx
HOW CAN I RESET THE bb SERVICE INDICATOR ON 2004 BENZ CLK? TKS
And stop hijakcing the thread. Post your question in the CLK forum, but before you do, do a search for that question in that forum. It has probably been answered in depth many times over...it is very common.
2003 S500 4MATIC
$150/pair for wiper blades!?! I think I paid around 30 for OEM Bosch; it takes about 10 seconds to swap them. The dust filter was a little more work but still pretty easy DIY. My advice is just pay for the oil change if you don't want to DIY it and do the rest yourself.
1 - 9 of 9 Posts
