Whenever I remove a car wheel, I always use torque wrench to bolt it back, which for the MB cars is set around 100 inch-lb. Today I wanted to check brake pads on my 99 wagon and to my surprise the impact wrench wouldn't move the bolts. It is electric one, that suppose to give 220 ft-lb.
So I had to get my industrial wrench to break the bolts loose, but what I estimate around 300 ft-lb bend extended heads of those bolts and now I have to replace them.
In my quite extensive experience as an enthusiast-car owner something like it happened only once, when on motorhome I had to use 8 feet long pipe to break the lug-nut loose.
Does anyone has an explanation how those things can happen?
I am in CA, where corrosion is not an issue.
