Where is it and how do i replace it.
And why do you want to replace it?Where is it and how do i replace it.
Absolutely correct. If everything is working properly, 45 secs. is the maximum run time.You might need to put a bit more time into cleaning them than just a screwdriver. It seems a long run time 6 minutes but I could be wrong. Mine runs for about a 45 sec to a minute. Might have a lot to do with ambient temp with the run time.
Sent from AutoGuide.com Free App
Yes under two conditions. If you started driving before the initial test was completed and the other is it will conduct a systems check whenever it so desires.I believe that air pump also cycles while idling at stop light as well.
Thanks for the clarification, 43!Yes under two conditions. If you started driving before the initial test was completed and the other is it will conduct a systems check whenever it so desires.
You only need to unscrew 1 bolt to remove the air pump, but be very careful not to touch vacuum hoses behind air pump. Look what happened to my 99 ML320. These vacuum hoses are so brittle, better not touch any, unless you know EXACTLY what you're doing.Where is it and how do i replace it.
