Changed the seats out for some from E-bay.... did not take too long but number one helper was into everything.
Regards
Regards
430 - 3/18/2005 8:27 PM
The seats are easy to swap out. The heating is controlled with a wiring harness that is easy to unplug.
MAX BLAKELY - 3/19/2005 1:24 AM
Seat's wiring harness is located under the front edge of the seat. Runs from floor up to the seat...there are three sets of wires/plugs to undo. Simply mark which plug goes where, unplug, put other seat in, and replug the wiring in the appropriate manner. Right seat has wires in right front area of seat and left seat has wires in the left front area of the seat---clever, those German engineers[] The seat itself is removed with the tracks by removing four bolts. The entire process takes about an hour...vacuum the carpet and tunnel under the seat. Made 26 cents on the deal in recovered lost change [
Regards
