2005 ML350 Special Edition
Hey guys
Before I posted I searched the forum and found a lot of interior light problems but nothing like mine....
What happens is that when I get in the car, I start the car up and while its starting up the lights go out and just the car starts up a second later the two overhead lights (reading lights) turn on and I have to turn them off. Would anyone have any idea what might be causing this???
Thanks in advance
Yes...I will get in the car shut the door...they will slowly start to dim and then go off....once I start the car the lights pop back on and I have to turn them off myself. I dont know if they turn off when I start to drive for a bit but I have driving like 20 meters and they are still on
Super Moderator
They are on a timer. Give it 20-30 seconds once the engine is running and all doors are closed.
Actually last night on the way home I tried leaving it on and see what happens and it actually was on for over a km so then I turned it off myself...
02 ML320 06 ML500
Try opening the passenger door and starting the truck and see if the lights fade out as they should.
ML320,C230, F250, Bayliner, Mountain Bike, Fleetwood Motorhome etc...
I hated that feature so I installed a toggle switch and put it where the garage door opener goes. You have to remove the whole overhead light assembly then wire in a toggle switch to both lights. Problem solved...
