21 - 35 of 35 Posts
2004 Clk320 convertible
Hi , I have ordered a C3 clone can anyone tell me if I need windows xp 32 or 64 bit ?
Super Moderator
32 bit will be fine. Depending on what version of the MB SDS software you are running you may need to go Win 7.
The latest version that will work with a C3 is the 2015 version which will need Win 7.
Thanks , i am trying to load a 2008 version on XP pro 32 bit , It is loading ok but I am having a problem with the DAS keygen . It seems hard work just getting Das running , I have not even connected it to the car yet !!!!
2005 CLK320
Has to be win xp if you want to use old c3, is you startkey center running?
How fare do you get when generating the key?
If you can get team viewer or any desk to work I can take a look.
Sent from my SM-G892A using Tapatalk
Thanks Paul , I am using Xp pro 32 bit on a D630 with SSD and the 2008 version of C3 Yes I get startkey running , but the key it generates is not accepted , I have attached some screen shots .
2677494
2677495
2677496
Super Moderator
I am wondering if the CommonLic.dll trick has to be done?
Can't even find my files for that.
2005 CLK320
Thanks Paul , I am using Xp pro 32 bit on a D630 with SSD and the 2008 version of C3 Yes I get startkey running , but the key it generates is not accepted , I have attached some screen shots . View attachment 2677494 View attachment 2677495 View attachment 2677496
2008 is so long ago I cant really remember, is this a DAS stand alone or does it include xentry?
You have to select the checkmark in the keygen and select a date.
You also have to select the correct version from the dropbox.
If this includes xentry you are using the wrong keygen.
Is there a reason to use such a old version?
I am only using this version as I was sent a link for it from another member , I have a 2004 Clk , I thought the older versions may use less resources as I am running it on a D630 with xp. What version would you recommend with a C3 ?
I now have Xentry 09/14 I have my laptop setup and I have made the 2 iso discs .
But I have a problem (again )
THe install starts fine but I get the following message
windows xp multilingual user interface pack cannot be installed on this platform"
Has anyone else had this problem ?
21 - 35 of 35 Posts
