1 - 10 of 10 Posts
Yesterday I acquired a 2018 Mercedes-Benz GTA roadster with the upgraded Burmester stereo system. It sounds fantastic, and I'm glad I spent the extra $6000 to get it in the car, which is by the way and unbelievable car.
Could not find a forum for that so Im posting here
My issue is that I have 16,000 MP3s and would like to utilize a 128 GB SD card to access those MP3s in the sound system.
In prior years, I was unable to do this because of the size of the SD card, however, my other car, a 2017 Mercedes-Benz GLE Coupe, which has a sound system from Harman Kardon, works fine with the 128 GB SD card and all the MP3s even in different folders and subfolders.
I have tried formatting the card for the Burmester in both fat32 and exfat different folders, but no success, this system, although it can recognize the card and the name of the card, it cannot see the files on it.
Is there any way you could help or guide me to a person that can tell me if the capacity to read this size card exists, and what I could do to access those MP3s. It may sound silly but it is very important to me.
Thank you in advance for your kind cooperation and attention.
W168, W169 Moderator
GTA roadster.....??
I doubt you will get any help, if it a GTA roadster....
GTS most likely.....:wink
Moved to GTS forum....:smile
Moderately subtle
I found the information on card formatting, capacity, allowable file types, etc, on page 137 of what should be your Command manual. Did you get one? I found it by Googling.
https://www.mbusa.com/vcm/MB/DigitalAssets/pdfmb/commandmanual/AMG-GT-Coupe-and-Roadster-COMAND.pdf
Thank you the truth is I did not have a manual for command included in my package. So this is indeed helpful. However, it states that apparently you can format the ST card in NTFS, ex-fat, or fat 32, but does not recommend any particular one. Nor does it reference a track limitation
I have been able to access about 14,000 tracks, however, and unable to see the last 2000 or so it goes to a "no music or video files" screen somewhere over 14,000. Unable to determine the exact number.
Apparently the head unit is different on the GTA roadster, then it is on the GLE Coupe.
Not sure what else I might try and do to get access to the last
Moderately subtle
The only limitation that I see is in the directory structure, no more than 8 levels. It does mention that a card with more than 64GB must be all music or video, etc. It has to scan the whole card to display the contents, and I expect that'd take a bit. I had a 128 GB memory stick in a Mini Cooper I owned, and when I first installed it, it took about 5 minutes to display all the music in the menu. Still 14000 songs at about 3.5 minutes per is 49000 minutes of music - aka - 800 hours. You'll probably be able to slug through that.
Do you mean 8 levels of the folder tree?
Fact is, both cars seem to read the file structure quite quickly barely takes 20 seconds
I'm sure I have more than 8 levels. The funny thing about it is my 2017 GLE Coupe has a head referenced by the Mercedes guy is a 5*1 and the GTA is referenced 5*2
You would think that the 2 is a newer version than the !. However
The Coupe head unit reads all 16,150 tracks with no problem but the roadster seems to have bumped up against this limitation at just over 14,000 tracks
Very curious
Moderately subtle
Yes, 8 levels in the tree from the root directory down to the "lowest" sub folder. It is quite odd one works and the other doesn't, sounds like a firmware issue. Wonder if there's an update.
Yes, I don't think I go down below 8 levels on any folder group, and anyway it doesn't seem which folder group I put on their it just stops reading somewhere about 14,000.
I wonder if there is any way to check the firmware versions?
More importantly, is there a way to force a firmware upgrade?
Question you could answer for me about upgraded Burmester
I have what I presume is the same system.
If you have an incoming Bluetooth call can you turn up the volume to a very loud level like the music and hear it easily with top down and road noise.
Thanks in advance
1 - 10 of 10 Posts
