Scrap or repair? Advice please
852 Views 22 Replies 5 Participants Last post by  DieselBound
Looking for advice. I’m in the UK I have a 2004 W211 E320 petrol with 117,000 miles. I’ve owned it 3 years and it’s been generally reliable but in retrospect, I don’t think I bought a well looked after vehicle and it already has a faulty parking sensor which is not a cheap fix with the bumper off. Anyway, in December I spent £1500 on new discs and pads and Michelin tyres and a few other repairs. Then I started getting terrible mpg and error messages. The garage have just read the fault codes and I’ve got the beginnings of a failing ABS pump (causing grazing brake pads, hence poor mpg) and leakage in the suspension air compressor. Each of them expensive fixes more than the value of the car unless I use reconditioned parts. I had been considering changing it anyway for something cheaper to run and in better condition but it’s such a lovely car to drive. I certainly can’t justify the cost of required new parts, but could possibly stretch to used or reconditioned parts. Alternatively, cut my losses sell it for scrap, buy a W211 diesel or a modern hatchback lol! At the moment, it’s still running fine, except for the mpg, any suggestions?
21 - 23 of 23 Posts
Look around for refurbished units. These should have the motor's brushes and such replaced as well as a new vacuum "ball." Nothing tricky or risky here. Deactivate the SBC (diagnostic tool OR just disconnect the wiring) and swap. There's work in bleeding the system afterwards but, from what I understand, it's not as scary as lots make it out to be: I'll for sure find out and I've completely disconnected ALL of my braking components (doing a restore on my car). Maybe try to find a shop that'll be OK with installing such a unit: dealer, for sure, wouldn't be OK with it.
I was told by the first garage that they were coded to the car so you couldn’t use just any parts. Is that incorrect?
You have to get one that's appropriate to your car (parts look-up based on VIN), yes. I believe that advanced diagnostic tools might have to be used to "introduce" the new unit to the car, but I don't have direct experience in which case I'll defer to the more informed folks here for any clarification on this point.
21 - 23 of 23 Posts
