Hi Scott, I really appreciate your getting right back to me. You're right, I should have PM'd you rather than start a second thread. I didn't think of it at the time. I've never done one. I couldn't edit the title of the other thread and I wanted to get your attention. Selfish of me.
Anyway, maybe this thread will help someone else with what to check if they have a problem:
Howdy Howdy,
In general the following is true......the ignitor either works or it does not. There is usually no "in-between." Considering the conversion was working well, and you suddenly get a miss, it's not likely the ignitor.
OK, thats good to know.
#1 - After install when you did the voltage test what was your input voltage to the coil at moderate/high RPM?
I remember seeing 18.9 ish, but I don't recall that I revved it up. I'll check it today.
#2 - Do you have both the black and red wire running completely out of the distributor, or have you spliced the black wire inside the distributor? The condensor has NO bearing whatsoever on the system.
Both wires out through, no splices. Originally I had just put the condenser wire back on its screw to keep it out of the way. I thought the same thing.
#3 - What cylinder are you missing on? The same cylinder each time, or different cylinders. The same cylinder and I would be looking towards a cap/wire/plug issue. If it is missing on different cylinders I would be looking towards the coil, or magnetic ring not fully seated. Simple test....take your timing light inductive pickup and put it on each wire while the truck is missing and see which cylinder it is....
That is something I didn't think of. I know it misses on #1 from using the timing light. I'll check other cyls with the light and see what I get. That should help narrow it down a lot. The mag ring is flush with the top of the ignitor and seems secure.
#4 - 6V, 12V, 24V, 36V - doesn't mean much on a coil. As long as you are running a 3 ohm coil that can handle the input voltage and has it's corresponding output voltage you are good to go. Your ignition system does not work on 24V, it runs between 17-21 volts.....hence the reason to check the ballast resistor output voltage on installation. Pertronix themselves spec'd the complete ignitor/coil combination after testing a complete stock ignition system. The 40611 is what they called for.....I could have them make up pretty 24V boxes and jack the price by 20-30%, but it's not our style.
Understood. Scott, is there a test I can do to check if the coil itself has gone bad?
#5 - What is your timing set at? Double check it.
14 deg BTDC at 850 rpm. I tried varying it yesterday between 10 and 18 for short runs with no change in the miss. The advance is working but I didn't do an exact test as to what maximum advance is.
#6 - With the minimal information provided, it is difficult to armchair diagnose your problem. Make sure it is an ignition problem, and not something such as a sticky valve, etc.
I hear you there. I have to do quite a bit of that in my business. I'm pretty sure its ignition related due to the fact that the timing light strobe falters in sync with the miss.
#7 - Does the problem happen everytime even when cold? IE.....does it take a while to start showing up, or immediately. On overvoltage problems we see the coil work fine when cold, but after running a while it may start missing...usually occurs right before complete failure. Rule out voltage issues immediately as if the coil fails, it WILL likely take out the Ignitor immediately.
It does it right from cold. I'll check the voltage first when I start on it today
Everyone has their opinion on the kit. Considering that the conversions have been on the markets for over 8 years, with a combined "test group" of well over 1500 installations...the kits are definitely a proven upgrade. However, it is not a silver bullet and is only going to work as well as the rest of the system.
You have some homework, report back and let us know the answers to the above.
I really like the concept of the kit. I wanted one the second I read about it and based on what others have said, it obviously works well and I will continue on with it. It's frustrating when you make an improvement to something that is already working adequately and the improvement fails, but then again, we still don't know for sure what the problem is either.
How much did you shorten the rotor for installation? When the rotor is installed what is the gap between it and the magnetic ring. My guess is the reason why your "condensor" fix seemed to work was because when you re-installed the rotor/cap it was seated down properly. I'll bet you have either not taken enough material off the rotor and therefore it is not fully seating, or you have taken too much off and it is know coming off easily....
I took off 1/8". There is a visible gap between the rotor base and the mag ring. The rotor snaps on very securely and is still securely fastened when I remove the cap, ie you have to pull on it a bit to pop it off. I don't think the problem lies here.
Scott, thanks for the checklist. I'll report back with voltage and a check on the other cylinders.
Again, I appreciate the help.
