Sold .....1987 U1250 Unimog
So anything on the mercedes list of approved oil is well a pain to obtain, and costly. Just like the rest of it.
I know the 404 trans have yellow metals. And need gl4
does the sbu fall in this category?
Will a 75 90 gear oil work?
Gl 4 and gl 5 be ok?
With all the oil options something must work locally
Sent from my SCH-I500 using AutoGuide.Com Free App
'91 U1250 '02 U500NA
I'm using Castrol Syntrans.
Dave search this forum, they've been many discussions on that matter already.
Unimog S 404.114
guude,
take care of oil without copper corrsion, GL4 and 5 says noting about even if oilspecialists tell so.
the synchronisation rings are made out of brass.
make a piece of cooper shiny, put it into the oil and heat it for an hour to ~ 80°C.
if copper is still as shiny as before it's ok.
gut 404! justus.
MERZ-1997-U-1350 LM Belgian Troop truck 366A-fast. axles-Binz Engine 220 HP HP upgrade in Nederlands
Hi Dave--my BW-U1300 has a brand new tranny in it from the MERZ factory---it came with 75W-90,- GL4 lube--"dino oil"-- from MERZ. Did not have Syntrans in it. It will work just fine. The MERZ book even lists 10Wt motor oil for BW trannys. I plan to change it out to the new 0-50 gear oil we are running in our Eaton Fuller trannies that our Peterbilts have.
Is essentially a GL4 75W-90.
TLane
Valvoline makes a gl 4 gl 5 combo. Seems reasonable for me
Even the book is pretty vauge it just list, 80, 75 90, etc. no real specifics. and as you said tlane 10 w motor oil.
To be honest I feel like I'm making a big deal out of nothing.
If it can take 75 90 or 10w motor oil...it can't be to picky right.
Dave
Dave--go to your local Peterbilt or Freightliner dealership and they will have the new 0-50
gear oil--is an upgraded 75-90 GL-4 (can't run GL-5 for obvious reasons due to brass in trannies) It is good stuff and is rated for 9 through 18 speed Eaton Fuller trans on the big rigs.
DELo--Shell-Mobil--etc all have it. Our Peterbilts have upwards to 2,5 million miles on them and trannies have never been repaired--we have been using DELO 75-90 GL-4 but are changing to this new 0-50.
The Castrol Syntrans is High Dollar---not needed.---In my own humble opinion--:)
