1980 U1300L
Anybody have a line on non-OEM (less expensive) rear view mirror brackets? Mirrors are fine, just the drivers side bracket is beyond repair, will buy a set if I have to. Thanks!
1980 U1300L
Thanks. I was looking to see if anyone knew of the after market replacement brand, or product line of the mirror brackets. I will ask on the classifieds, thanks.
U1450L DOKA
Personally, I'd stick withe the OEM brackets.
They'll fit,,they are stout, they look right, and you don't need to worry about making
Adaptor plates or drilling new holes and using rivnuts or the like....
They can be found..
Unimog U1250
I had after-market mirrors on my truck when I got it - replaced them with the genuine ones as they didn't look right, and didn't have the "fold back" feature and had all sorts of excess brackets to stop them from vibrating creating lots of holes in the truck door.
I bought a genuine set of arms, and then modified them to fit them closer to the body - the arms are pretty substantial wall thickness - 4-5mm IIRC.
'76 1300L,HE351CW,H15P Winches,Konis,Hydraulics,All Gears,10mm Plungers,Aftercooler,Lots of Littles
Trucklite makes mirrors that work and look fine. Around $15 ea complete.
C.
