If it was a frequency and/or bandwidth issue as you posted, unless the FCC made more frequencies available, the cause of some earlier vehicles not receiving the higher stations is not likely a SiriusXM issue but rather a manufacturer issue with the hardware/software in the vehicle. I would love to know how much of it is software and how much is hardware. Can the manufacturers patch/update existing hardware to tune in these higher channels? or is it a limitation of the hardware? I once read that satellite radio broadcasts every channel all at once but must do so in the same band, 12.5MHz. I admit, I do not know enough about satellite radio to answer my own question but at first glance, it seems that all channels must fit within this same bandwidth. This is why they allocate more for music than talk radio and why talk radio isn't as clear. If this is true, then every radio receiver must be hardware capable of receiving the full 12.5MHz spectrum. This to me, if all else is true, that each OEM is leaving out channels on purpose.
