2006 CLK 350 Cabrio
I want to buy the module and install myself. Need assistance on the following:
1. Are the needed power and fiber optic cables routed and available in the trunk compartment (I assume its the one in the right corner)?
2. If so, need wiring diagram or labels of the harnesses I will need to connect to module
3. What is the part number for the XM/Serius Satellite module for my car (trying to find in Ebay or salvage)
4. where does the bracket attach to
5. Any other helpful advise greatly appreciated!!!
many thx!
You need more than just the Sirius tuner - you also need the installation kit that includes the bracket and proper wiring harnesses for tapping into power and fiber connections. It's not an easy job - there is a lot of tedious work in the trunk adapting wiring harnesses and connectors. You also need an antenna, but that's the easy part. The kit is in the $600-$700 range. As much as I enjoy Sirius, I don't know that I'd invest that in the stock radio. Instead, I'd put in a nice aftermarket radio with sat radio, Bluetooth and iPod.
