1 - 12 of 12 Posts
It's time to retire that noisy and inefficient GM R4 compressor, and "Sanden-ize" your A/C system.
I am offering this Sanden style compressor mounting kit for $200 +S/H/I (as of June 1st 2015). The kit comes with the mounting plate, hardware, belt, and plate brace. The kit will fit OM616 & OM617 Diesel engines, turbo and N/A.
I also have available: New 5 cyl compressor (NOS) $200, 7 cyl $220. Hose kit $100, Drier $20.
The complete kit (5 cyl) is $520 + S/H/I (2- Priority Mail packages @ $20 & $25) for a total of $565. Add $20 for the 7 cyl compressor.
If you are running a Parallel Flow Condenser, you will need an additional hose @ $20:
Please P.M. for details.....Rich
1984 MERCEDES-BENZ 300 TURBO DIESEL, 1978 CHEVROLET K20 CUSTOM DELUXE
Sounds good. I want to get rid of my r4 but the funds don't permit it yet.
1981 300 SD
Do I need to change the evaporator or condenser to do this up grade. My system currently is functionable. However, I have had the compressor changed once and the clutch on that comprssor once by MB. And the current clutch is going bad. It has never been vary efficient.
1985 Euro 300TD Turbo, 1983 Euro 300TD turbo, 1979 Euro 240TD and 1981 300D converted to euro.
Does that top low side ac line still need to be silver soldered to the factory fitting or is it plug and play yet?
Discussion Starter · #7 ·
Kit and parts availability
I no longer sell compressors, so they will have to be sourced elsewhere. The Sanden #4272 is needed for the kit. It is available direct from Sanden, or other vendors (ebay, A/C parts warehouse etc.). I only sell the bracket kit, hose kit, drier, and fan relay. If you are using a parallel flow condenser, they are available from ebay. A 16X20 for a W123, 16X22 or 24 for the W126.
1973 416 Doka, 1978 416 Doka, 1980 416 Doka..... Help me, I can't stop buying them!!!
I have put Rollguy's kit in both my wagon and my coupe and the AC now blows ice cold when outside temps is in the mid 90's using R124. Kit is well made and easy to install. I put in the new condensers which I got off Ebay. I highly recommend it.
Reactions: jonwhite99
Hello,
is there any way to use this conversion kit for a variable displacement Sanden compressor, as well? I am looking for some way to convert from the old R4 compressor to a variable displacement compressor. For the 240D, it's quite unconvenient to have compressor kick in, so it would be a lot nicer to have the compressor running at low loads continuously.
Regards,
Boris
Discussion Starter · #10 ·
I am not on BW much, but these kits are still available. The updated version (Gen III) has a thicker plate, two braces (Gen II had one), and two adjustment bars. The mount kit is $250. The standard hose kit (two main hoses) $120. New drier $20. If you want to use a parallel flow condenser, an extra hose is needed- $20. Dual fan relay (suggested) $40. Upgraded belt (made by Continental) $10. Shipping/Handling/Insurance for the above $30. Rich [email protected]
2639997
2639996
2639998
2639999
Discussion Starter · #12 ·
Please download the PDF Installation Guide from post #1 above
1 - 12 of 12 Posts
