1 - 1 of 1 Posts
2011 R350 BlueTec
Rising temperatures puts extra stress on your A/C system, so repair or replace your system before the temperatures really get hot!
Series Resistors On Sale!
The series resistor makes it possible for your A/C system to have different speeds.
It lowers the voltage to the fan to slow the fan down at low speed settings. If your
cabin fan only works on the highest setting this is an indication the series resistor has failed.
These fail when they overheat, so failure is much more common during the hot months.
Check out these top sellers
Blower Motors On Sale!
Blower motors are the actual fan assembly inside your vehicle’s A/C system.
The #1 cause of a failed series resistor above is a blower motor that is drawing
too much amperage.
If you are replacing a failed resistor we strongly recommend replacing the blower
motor at the same time. Blower motors are easy to replace on most models.
Check out these Blower Motors!
1 - 1 of 1 Posts
