Hi
the ML sags to one side and when you go over a join in the road way the sound of rubbing from in the wheel arches. Often the sound is either front or back wheels fomr the sagging side. Any hints whats the problem is likely to be ?
2000 ML320
If the air spring is the issue, and you can figure out that by using the spray bottle and detergent to see if the air is leaking. Usually it leaks on the bottom part of the flexible rubber. Replace both rear ones as soon as possible otherwise, you will have to buy new tires in few months.
