Hello time to upgrade my 16” rims and want to make sure I have expert opionion before doing it.
Will the 2 piece 18” s65 rims fit on a 2009 E320 diesel (is this a good idea?)?
If not what size spacer do I need to make it work?
Is 700.0 for a set of 5 rims and tires good deal? They all come with Goodyear eagle f1 tires that is 70%
I try searching the forum but could not locate an answer. Thank you!
w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
You're missing some important information in your post.
Depends on what your 16" rim offset (ET) is and what the 18" offset is.
(most likely stamped on the inside (backside) of your wheels.)
You also need to know what the present tire size is and what the 18" tire sizes are. Swapping to larger diameter wheels and tires will still require you to closely match the oem wheel diameter specs.
Pricing? That's up to the eye of the beholder.
Do the tires have even wear? patches? road rash? age of the tires? All these should play into your decision.
