S600L ABS light
969 Views 6 Replies 4 Participants Last post by  dtkw
Can anyone tell me how to find the cause of ABS warning lamp coming on when driving, it goes out when engine starts, but after a few miles will come on,sometimes after 20 or so miles. My local dealership tells me that it is very difficult to tell the cause,and could be very expensive!! to cure.has anyone had similar problems.
92 500SEL to 01 E320T current 2014 lexus LS460
ABS
Check your tires, make sure they are the same size and type, possibly tread depth.I read an article that claimed the light could come on due to the number of rotations of the tires? the other could be the sensor on the wheel(a toothed affair) and the magnetic pickup getting /or not/ pulses.
86 560SEL
Could also mean your ABS unit needed to be replaced. And don't take it to the dealers, th...
Could also mean your ABS unit needed to be replaced. And don't take it to the dealers, they just rob you out right. Since your car is already 10 years old, you could get some rebuilt parts like I did. They all come with at least a year warrantee I think.
86 560SEL
Or just take it to the empty parking lot on a rainy day and try it. Slam on the brake to ...
Or just take it to the empty parking lot on a rainy day and try it. Slam on the brake to see if the ABS is kicking and stop with no drama. Keep us posted.
600sel 1993
Discussion Starter · #6 ·
Re: Or just take it to the empty parking lot on a rainy day and try it. Slam on the brake to
works OK when light is out,when ABS light comes on the ASR light also comes on and ABS does not work......[?][?]
