"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Swapped out the original Airfilter boxes & installed the look alike K & N filters for testing ,these are only cheap at 24,95 $ eachplus $13 for each joint.
Once I see all goes like I want it to I get the real once or better .
You need a sleeve 3 inch by 3 inch joint or 76 MM,so measurements for the filter are 76MM so for the Joiner.
Also there is the need to make a bracket that holds one of the filters as it hangs there ,I haven't done that yet that's why the airpipe on the passenger side underneath .
Driving slowly there is no difference in engine sound but slightly tap the accelerator a bit more & the real beast sound of the V12 comes out of it now ,hit that pedal to much & you got the heads turning , I think it sounds just like an Aston Martin V12 with a bit of Lamborghini in between ,absolutely awesome sound .
When I drove the car for a test run ,the engines behaviour was perfectly normal ,no weird misfiring's or weird gear shifting's , just to mention this .:thumbsup:
BTW Joe : If you drive without the Airfilters on ,there is another filter just before the inlets ,small enough to catch mosquitos ,picture below.
Richard ,This setup will make you forget about the Ferrari's ,lol.
