2005 S600; 2007 GL450; 2004 E500 4Matic; 2002 C32 AMG; 2001 Trans Am WS-6
Tracking down an oil consumption, plug fouling, and misfire issue has led me to remove the pressure valve that diverts the crank case ventilation from the driver side oil separator to either the right manifold (partial load) or the charge air intake (full load).
I discovered the diaphram inside the valve is completely disintegrated.
Upon further investigation, it looks like the seal ring that surrounds the camshaft in the housing may be not sealing.
My question:
Does the valve cover have to come completely off to remove the seal ring, or can I pull it out from the front?
Part numbers in question are:
seal ring: 2759970346
Diverter valve: 2750100291
(parts labeled 455 and 460 in the exploded diagram here:
CYLINDER HEAD. Fits: Mercedes | Mercedes-Benz of South Atlanta
Thanks!
My question:
Thanks!
