I brought in our '94 S600 to the shop because of rough idle and stuttering engine, the dealer said that the engine and body harness must be replaced (3K!!) as the harness has cracked and the wires inside are exposed and probably could lead to futher engine problems. Any thoughts on this or similar experiences ? Is it really necessary to replace the harness ?
Discussion Starter #2
This fault is apperntly common amongst the warmer countries. Here in South Africa the harnesses do perish due to the heat.<br> Regards, Susan Calitz<br> owner '95 S500
owner '95 S500
