DTC codes P300 and P308. Live data shows misfire on cylinder 8 but only when starting. No issues at idle. While driving (in an empty car park) seeing almost continuous faults on cylinders 3 & 4 and intermittently on 1 & 2.
Clogged Catalytic? and is this 2 problems (one affecting #8 during startup and another affecting right bank cylinders while driving)?
Any additional diagnostic tests recommended?
Vehicle was recently purchased, sat for 6+ months previous and has 170k miles on it.
Work done to date (not necessarily to address the issue above but perhaps related)... plugs & wires; fuel pump & filter; trans fluid, filter, plug adapter & cleaned TCM of oil; water pump, thermostat, serpentine belt, idler pulley, tensioner
