1 - 10 of 10 Posts
2002 500S
I just had this problem and the valet key would not open the trunk. I checked this forum but ultimately called MB Roadside to get the trunk open. The approach he used was to use a jumper cable from another vehicle to the alternator. On my 2002 model the alternator is on the left hand side of the engine (looking at the engine from the front of the car). All he needed to do was to remove the front piece of an air supply hose (~3" diamerter) to gain easy access to the alternator post. He attached the positive cable to the post and the negatve cable to the engine (any thing metal & non-electrical will work). He let the battery charge for about 5 minutes, started the car, and used the fob key to open the trunk.
The best bet if your car is covered by MB Roadside is to just call them - it takes about 20 minutes.
Hope this helps!
I still have the mechanical lock issue. The MB Roadside person told me how to go about getting to the lock and potentially determining what the issue was.
Lots of collector cars from the 50's to present
Not always so!!!
MBZ came out and couldn't get in. I had to actually drill a hole behind the license plate and manually pull the lever to open the trunk. Sometime, you have to do what you have to do. Even the guy for MBZ roadside assistance was stumped. I said I would drill exactly where I thought the rod would be and I go it on the very first try. Then I had to use a body plug to fill the hole and put the license plate back to cover the body plug. What a pain my ass.
2006 Mercedes S55 AMG
You guys do know that under the carpet of the pass. side floorboard is a power junction with positive and ground where you can supplement power to. No drilling holes in your vehicle necessary! That seems like a very big security breech to me.
If you're locked out you have to use your manual key to open the door of the car and plug in to pass side under carpet.. if your battery is completely dead, your locked out of your car, and you lost your key, well then, you've got bigger problems..
I wasnt locked out of my car I was lock out of my trunk. I was just saying even the MBZ guy couldnt get im in the trunk. The actuator latched and wouldnt release. This was the ONLY way in. The other guy said his key wasnt working but I will say, having the jumper inside is a blessing not something to be unhappy about. Thanks, glad to know!!!!
No prob.. I am surprised every time by the amount of people who don't know this, even experts.. I saw a MB mech. do that when his employee locked the trunk on an S600 with an uncharged batt.
E320 Yr 2000, S430 YR 2002
I have a broken mechanism. Before I make a big hole in the trunk cover, can you tell me the size of the hole he made and whereabouts please, if you remember ? Is this something that may be covered under the car insurance ?
I bought a 2" inch drill saw with the bit in the middle. It takes only a little pressure to go through the entire two layers of the plastic, the lid and license plate cover. If your car is black then it's a no brainier, they will come pre-painted in black or silver and maybe some other colors. Sometimes you can order your part repainted. I just put a special adhesive in the hole and put in the body plug and covered it with the license plate, no big deal. You must drill right above the bottom license plate screw hole just to the right on the left side. Do not push hard or go deep, the hole will come within 10 seconds of starting. It's thin material. You will see the rod. Pull it and the trunk will open. Remember the drill saw bit if you buy a 1 inch will make a 1/14 " hole and you can use needle nose pliers to get to the rod, pull up and it's open. The pull the carpet off and remove the unit. I made the mistake of buying a 2" cutter and it made the hole 2 1/4 " hole. I moved my Serial number decal out of the way so to leave it in tact and put it back afterwards. Its not covered under car insurance, sorry. The bit is about 10.00 and that is all it costs to get into your trunk.
I would however call the MBZ guy to come out he might be able to get into the trunk without all of this. Mine was my stupid mistake, I put the rod back too long and no matter what I did the key nor the mechanic could get in other than me cutting the hole and it was screwing up my electric closure and messing with the hinges, I had no other options.
1 - 10 of 10 Posts
