1 - 16 of 16 Posts
All,
I am trying to find the correct location for the outside temp. sensor which is located on the bumber. Mine was damaged and removed because the bumper had been damaged. I am getting another bumper and temp sensor, and I need to know where it is suppose to be situated. A picture of the location would be very helpful.
Thanks!
current fleet: 1996 s500; 1997 BMW 328ic; 2000 Nissan Frontier; 1966 AC Cobra
not sure of your year - please advise
on my 96 s500 I believe the abient temp sensor is in the cowl intake near the windshield.
I could be wrong - but I thought it was there rather than in/around the bumper.
hope this helps
I did some checking - I believe your ambient temp sensor is not near the bumper; it is near the cowel intake near the windshield; near the cabin air filter
hope this helps
2008 E 320 Bluetec (ELEGANCE) 2005 CLK500 (avant-garde)
On mine (admittedly much older) the sensor is in the towing eye cover on the drivers side
1997 S600 (sold)
hope this helps
Pretty sure there are two different sensors. You're talking about the climate control sensor. The instrument panel display sensor is clipped into the pop-out panel on the driver's side of the bumper.
Brett
1999 S600 Sedan, 1999 S600 w/ 4-pl seating, 1995 S600 Coupe, 2-1992 600SEL's, 2002 ML55, 1998 SL600
The outside temperature sensor is mounted on the driver's side tow-hook cover. There is a small metal clip the sensor mounts on once inside the cover. The sensor itself looks like a small probe attached to a long wire. There is NO temperature sensor in the bumper itself, it is in the tow-hook cover.
Inside temperature sensors are in two places: the very front of the dashboard near the windshield between the defroster vents on 1997/8/9 cars, and a secondary one in the small box behind the rear view mirror, and in pre-1997 cars, that one is the primary temperature sensor.
1997 S500V, 1999 S500 grand edition, 2006 s65 amg
i have a 97 that needs the outside temperature sensor replaced. since mine has a short because the sensor is defective. my temp screen turns off every now and then and according to STAR Diagnostics its the temp sensor. does anyone know the part number?
1994 Benz S320 SWB / 1986 Porsche 911 Targa / 1998 Benz CL 500
It doesn't exactly "fit", I fixated mine with a glue gun from the back after the wiring job and everything that is, its been sitting there for nearly over 2 years now maybe even 3 years, no problems yet.
How ever you wish, it was only a suggestion:) I didn't damage anything either, its nearly one quarter of the price compared to the original, the only thing I did was to strip the wire and connected to the W220 temp sensor, I didn't drill a hole or anything.
1995 Mercedes-Benz S420, 2011 BMW 535i M-Sport
Here is a picture of mine. Sorry, this is an older picture, I wasn't trying to take a picture of the sensor.
-------------------------------------^temp sensor
1 - 16 of 16 Posts
