///s320...ur turn signal assembly
870 Views 2 Replies 2 Participants Last post by  ///S320
Hey s320
Where did you get your clear turn signal front lights...and did you install them yourself...was it complicated?
thanks
ghost
1997 S600 - Bentley Turbo R (black/black)
Discussion Starter · #2 ·
its ok i saw your post on mbworld
s320:
i read your post on mbworld.org...u mentioned bekkers for your turn signals....i think i found them cheaper at speedyparts.com...they are bosch..i hope they are the same ones...
thanks
S320W
Hi ghost,
The assembly is super easy to install. There is a clip inside the engine bay th...
Hi ghost,
The assembly is super easy to install. There is a clip inside the engine bay that you need to pull and it comes out easy. But remember that you need to get only orginal Bosch equipment.
Hope this helps!
