Hello All.
I bought another S320(1999) last weekend,and am very satisfied so far
The seller bought it from an auction and only kept it for two weeks,so I assume he got it with even less money.
It has an awesome MOT history(passed every year at first attempt 2003-2016,but since then it has clearly fallen to the hands of poor owners. 370Km/247 miles on the clock.
I paid only 1400e,which may not impress american people,but here in Finland it´s a bargain..even if there are faults in the car. It´s got a lot of valuable parts in it,but if nothing serious shows up,I´m gonna try and make it a reliable and useful,beautiful car.
The car´s been painted with a matt grey colour,”the cheapest available”as the seller suspected
Actually,this is the best part of the whole project!Now that I don´t have anything to lose,I can choose some awesome colour and practise my spraygun (non-existing)skills .
If I am to go for an original Mercedes colour,then it might be Titanite Red(576?).
Here´s a quick look at the good and bad things I´ve discovered so far:
+ Engine and the whole drivetrain seem to be in order;very nice shifting and the engine is smooth.
+ Motor- and transmission mounts seem to be ok
+ No warning lights
+ No Airmatic problems,stays up.Arnotts in three corners and one new,unknown brand(chinese
timebomb?)
+ OBD test passed.Overall,iCarsoft didn´t show anything alarming.I think I finally need the SDS.
+ Incredibly good interior,although black is not my thing at all.
+ 2 good set of rims.The car had tyres 205/55/16!!! I have the original w220 rims+good tyres,so put them on.
+ Good windshield and wipers.
+ Sunroof works.
+ No dents (who knows what´s under the awful paint,loads of body filler?)
____
- Pixel problem in the odometer info section.
- Rust at the doors,but nothing too bad,really(?).Underbody seem to be fine.
- Only one keyfob,no metal key.
- Blower is not working at all,windows get foggy.I need a new one,because this is a FORD blower!
I discovered a burnt fuse and half melted fuse housing,which still works,but obviously I´m going to get the power elsewhere(you know where).Must test the regulator and buy a blower(or both).
- Driver side door module won´t work.Some previous owner have messed with wiring harness which goes to the door.That worries me much.I´m going to test the module by connecting it to the right side. Encyclopedia: ”The physical location of DCM is programmed into DCM. E.g., if left DCM is connected to right side, the DCM will still move left seat.”
If only I could move the chair so that it fits me,that would be good enough for now.
- Trunk closing actuator is clearly faulty:no soft close,and it loudly release air for a few seconds when I open the trunk.Also the hinges may be bad.In the picture you can see the upper part of the trunk is...upper. Sometimes it´s difficult to say,which is the cause and which is the symptom,but I guess that the hissing noise behind the lock would be the first thing to check and work on.
___
I can´t get the car indoors but I´ll slowly do what I can and keep you informed..in case someone there is interested.There surely will be questions,too.In fact,I have one right away:
I´m eager to get the hvac working,even if only temporarily,so at least I could test it.Is it safe to use, say,w210 blower with the w220 regulator?
+ No warning lights
timebomb?)
+ Sunroof works.
____
___
