w220 S-500. car was in the shop for AC servicing they said radiator was bad so it was replaced, now AC is cold but when car is started it will heat up to 80c and stay there but As AC cools cabin temp, engine temp goes up will stabilize at about 95C.As AC temp goes up, because cabin has reached selected temp I guess, engine temp will rise to red line stop driving car let it idle and temp goes back down to 95C, did not touch AC controls. Next took car, after it cooled down, on highway at 70mph it got hot put it in neutral with engine idling and car slowing temp went down,great car in traffic stays at 95c,AC not cold. On initial start up AC is great ice cold goes to hell when system tries to maintain temp by warming cabin. could something be restricting the flow of engine coolant at rpm above idle when cabin temp system is working DUNO valves maybe ?? diagram looks like it dose. Note below 50 outside air temp car seems good (or maybe i should drive it further)this all happens in 50miles or less.
Thank you for letting me rant
