I have a 2009 sl300. I’ve replaced a tire and because nothing on the tire gave any indication of run flat I replaced with a non run flat. But when I turn on ignition it says reset run flat indicator which would suggest I should have put run flat on. How do I tell if I should put run flats on or if the previous owner just put the wrong tire on thanks Nick
Did you put the same size tire on. One type of tpms detects tire rotation.
Sent from my SM-A505U using Tapatalk
hi thanks for responding - yes same tire. a confusion arises as The dashboard says reset ‘run flat restart’ which implies I should have run flats??? Thanks again
