Dear community, I have W245 200 CDI (EU)
The Runflat system, seems to be working, correct me, but it's working via ABS sensors, not the pressure sensors in the Rim.
I tried to flat one tyre today to 1 Bar , others were on 2.5 approx, and I didn't receive any warning.
A bit odd.
Any suggestions?
Br,
Jan
· W168, W169 Moderator
A150, A180 and B200 CVT, A140, A160, A170,A190 And A210
The warning light should come on when you drive the car because the flat tyre will rotate faster than the others.
Hello, Yes I am aware of that, I drove 50 km/h. I had a leaking tyre 2 years ago, and the indicatons were working without a problem.
I connected it to Autocom diag, under Instrument section, I found TPMS , and it is: no errors
· Benzworld Staff
Night Crew......2006 B 200 .....& Audi A6..
Mine often shows a reset required when changing tires and rims from winter to summer driving. The air pressure is very sensitive to fluctuations in any variance in the tire pressure..
There is a notice/dash warning when driving at any medium highway speed if the tires are out of equal pressure. There is also a "reset" requested and that is easily performed by the steerring wheel buttons. Well explained in the in car book manual if I remember correctly. If you don't do the reset..the messages will add up and show in the dash.
