1 - 13 of 13 Posts
Hey guys. I have the rubber floor mats on top of my regular OEM carpet. The rubber mats are very dirty and today I used soap and water to clean them. The problem is when they dried they were still very dirty with dry, tacked on mud and dirt that I can't seem to get off. Anyone know how to properly clean them?
I have the OEM mats also, but they have never gotten that dirty. However, the last time I had a detail shop clean the rubber mats on another car of mine, they sprayed them with a degreasing solution, let that soak for a few minutes, then they sprayed them off with just a garden-pressure water hose. They then looked practically as good as they did when I bought them about 14 years ago!
Something as simple as mud should come off with soap/water and a stiff scrub brush. Are you sure that is only mud?
Hope this helps,
M
I would let them soak in warm/hot water for about an hour. That should soften the caked mud. Then wash with Simple Green or any all purpose cleaner. As mentioned above, if you have a pressure washer that should do it.
Alright I'll try soaking them. I rubbed soap and water with my high powered hose and after it dried it looked dusty still. I have OEM mats too and scrubbing inbetween the honeycombs is a pain.
I soaked them in hot/warm water for about 20-22 minutes and I scrubbed them. Frustratingly (idk if thats even a word but w/e) They remain dirty. I spend so much time trying to clean them but they still are so damn dirty, IDK what to do? Will tire cleaner help because they are both rubber...
WhyteML,
Try looking on the Autopia detailing forum for better suggestions. Be prepared to search a bit. You could try the tire cleaner or degreaser on a small unobtrusive area as a test (perhaps a single honeycomb near an edge).
Good Luck,
Glenn
I also have the OEM mats. I have had good results by spraying on some Kleen Green, water and then scrubbing the mats with a fairly had scrubbing brush. Came out looking like new.
Greg
Hey WhyteML,
I've used Meguiar's Heavy Duty Vinyl/Rubber cleaner for the past several years with great results. It is typically found at Auto Paint Supply stores that normally sell to body shops, detailers, etc. I don't know what's in this stuff, but it works; spray on, let sit for a few minutes, brush lightly on stubborn spots, wipe or hose off. The other post about applying a surface protectant, either 303 or Meguire's is a good idea.
Bob
After cleaning give them a good coat of Zaino Tire and Rubber dressing. Makes them look brand new every time.
S.A.MobileDetail said:
What works great for us is Simple Green, let it soak for a few, scrub and power wash.
The winter took a beating on mine. I think i will try your simple green idea, good stuff. Do you powerwash them or just reg. pressure?
My regular OEM MB carpet floor mats that came w/ the car held up very well for six years, but the last couple of times they got washed left them loose and they now bunch-up when feet push them. This is a real pain now, and I was wondering if there is any way to rejuvenate them or do I have to buy new ones. I never liked the plastic stuff and don't mind replacing the carpet ones if I have to. Six years isn't bad. They still "look" good, but the bunching-up crap is getting annoying. Anyone else experience this? Any fixes?
1 - 13 of 13 Posts
About this Discussion
11 Participants
Jayhawk
Mercedes-Benz Forum
Full Forum Listing
