1 - 9 of 9 Posts
190 e 2.3
new to ownership of 190e 2.3 and first time i've had a 4cylinder. is 65 mph with 3000 rpm's a normal ratio? seems high but new to 4cylinders. anyone know where i find the shifting rpm info? thanks
1984 190E 2.3 8v
pinto1212 - 1/29/2005 7:49 AM
first off is yours a auto or std?
3000 is normal for a auto tran.
190 e 2.3
Many thanks. it's an automatic. and some others have said what you did.
do you have a repair manual? i got a Haynes one used, but it doesn't seem that great. for instance it didn't give the gear shifts. but thanks for the answer. phil
1983 300D
i also had a rpm/mph question. i have an '88 190E (2.3.. stifling 8V) and at 3500 rpm i'm going about 70-72. if i go up to 80 (mach 1 for the 190E :)) it hits right around 4000. is this normal?? i also read on here about a timing retard resistor. does that apply the the 2.3s too?? can i try and remove it or should i find/order the 2.4Kohm (do i have to go to the dealer for that??).
thanks.
1988 190E 2.3
Phil
You can download a copy of the W201 manual in the FAQ section. It doesnt contain much on the tranny's though. You mentioned something about yours not down shifting are you having problems with the tranny
1988 190E 2.3
thanks.
Check here for a real good explination on the resistor. You can get different sized resistors from the dealerPerformance Upgrades and yes the RPM's are normal mine runs about the same.
1 - 9 of 9 Posts
